Yes this is also for the new Minix X8 Plus.
BUT IT IS NOT FOR the Minix X8-H Plus! DO not flash this to your X8-H Plus or you will loose your special boot keys!
This is a full ROM and you can flash this over ANY other release!
Yes you have that correct! It will replace ANY ROM you currently have! This is because I erase everything and start you fresh! Something a FOTA update does not really do. Trust I think this is better especially if your having problems and need to start fresh!
One thing about FOTA.... If your jacked up due to issues, it will never be like a fresh install! I now provide you that capability with this flashable ZIP.
A TRUE CLEAN install of 003 like your box was brand new!
This keeps you from flashing a OLD ROM then updating using FOTA. A TRUE clean install
NOTE: THIS WILL ERASE YOUR DEVICE! So backup anything you want to keep!
____________________________________________
DO NOT just put this download on the SDcard! Unzip the download and see the readme instructions!
Here are the download links.
ROM -> Minix X8/X8-H - 003 Stock ROM in ZIP format - (487 megs)
Enjoy,
