THIS IS NOT FOR the Minix X8, X8-H or the new X8 Plus!
This is a full ROM and you can flash this over ANY other release!
Yes you have that correct! It will replace ANY ROM you currently have! This is because I erase everything and start you fresh! Something a FOTA update does not really do. Trust I think this is better especially if your having problems and need to start fresh!
One thing about FOTA.... If your jacked up due to issues, it will never be like a fresh install! I now provide you that capability with this flashable ZIP.
A TRUE CLEAN install of 003 like your box was brand new!
This keeps you from flashing a OLD ROM then updating using FOTA.
A TRUE clean install
NOTE: THIS WILL ERASE YOUR DEVICE! So backup anything you want to keep!
____________________________________________
DO NOT just put this download on the SDcard! Unzip the download and see the readme instructions!
Here are the download links.
ROM -> Minix X8-H PLUS (only) - 003 Stock ROM 02/07/2015 in ZIP format - (489 megs)
Enjoy,
