Anyone know how to do a recovery or hard reset?
UG007 - stuck in endless boot up
Originally posted by atf678 View PostJUst tried to turn on my UG007 today and it's stuck on the bootup screen.
You need to enter only 1 string:
reboot bootloader (it will reboot in bootloader mode) after this You can flash any firmware You like but don't install Finless, You will loose WIFI/BT functionality.
2. open the case and turn on UG007 with short 2 pins near flash chip (not soldered recovery mode button). If You will do all correct your UG007 will go to recovery mode on boot.
Instruction where to short pins You can find in recovery tutorial for UG802. In UG007 these pins on same place.
3. You can make special microSD card, when this card inserted, it brick's UG007 on boot and it will go to recovery mode automatically on reboot(this way for working device).
I have the case opened up and at first it didn't look like the pictures of the UG802 and there were so many solder pads that looked similar. And then I turned the board over.....doh it is virtually identical.
I'm a bit afraid to test other rom's. Would I be able to keep flashing other roms or get back to the original one if I fail or brick it?
All I see are Finless roms for the UG802. What are the other roms that you mentioned that would work?
Thanks for the help.Last edited by atf678; 18 November 2012, 16:16.
original firmware
Originally posted by 2dark4u View PostYou can install only original UG007 firmware no custom ROM available for now.
If you can upload this firmware somewhere, a lot of people are wanting it!
As to flashing it, is there a rest button anywhere on the device? A little pin hole hiding a reset button?
Where? All sharing server support max 200Mbyte. And the image is 378
Originally posted by Finless View PostIf you can upload this firmware somewhere, a lot of people are wanting it!
Finless look at thread http://www.freaktab.com/showthread.p...ginal-firmware
We trying a lot of firmware, all work but Wifi and BT NO.
I'm waiting my seller support. When I find good firmware I post immediatrly IT.
Originally posted by andrea_ita View PostWhere? All sharing server support max 200Mbyte. And the image is 378
Just PM me the link please as if you post it in public in 30 minutes it will be banned!
There are currently 1954 users online. 0 members and 1954 guests.
