SICK OF MOUSE POINTER - How to disable mousefunktion at all ?
    Im using my M82B just for XBMC and tried a lot of 2,4ghz airmouse remotes, because the original IR-Remote from the box is crap.
    Of course there are some 2,4 ghz remotes where you can disable the mousefunction but it does not really work well in normal use.
    So does someone knows how to diasable the mousefunktion for all times in the android system.
    I just want to control my box with the arrow keys and see no more mousepointer.
    Is this possible ? What can I do ?
    I would like to know this as well.
      If you take a look at your /etc/remote.conf (Though say WinSCP), I think you'll find that Function "388", is the One that controls the "TV_KEYMOUSE_MODE_SWITCH" (e.g. Mouse Mode)...
      You may wish to try and noop this Function by placing a "#" in front of it, like so...
      Thus disabling it as a "Function". How this would work for an Air Mouse though? I wouldn't know AFAIK Function 388 is for the IR Remote Mouse Mode, Stock or otherwise...
      Code:
      #this file is configuration for each factory remote device
      #     work_mode      0 :software mode  1 :hardware mode
      #    repeat_enable      0 :disable repeat 1 :enable repeat
      #    factory_code      each device has it's unique factory code.
      #              pattern:custom_code(16bit)+index_code(16bit)
      #              examble: 0xff000001 = 0xff00(custom cod)  0001 (index)
      #    release_delay      unit:ms.release will report from kernel to user layer after this period of time
      #              from press or repeat triggered.
      #    debug_enable      0 :debug disable  1 :debug disable
      # SW MODE:
      #    bit_count      how many bits in each frame
      #    tw_leader_act      time window for leader active
      #    tw_bit0          time window for bit0 time.
      #    tw_bit1          time window for bit1 time
      #    tw_repeat_leader  time window for repeat leader
      # REG
      #    reg_base_gen      set value for PREG_IR_DEC_BASE_GEN
      #    reg_control      set value for PREG_IR_DEC_CONTROL
      #    reg_leader_act      set value for PREG_IR_DEC_LEADER_ACTIVE
      #    reg_leader_idle      set value for PREG_IR_DEC_LEADER_IDLE
      #    reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE
      #    reg_bit0_time      set value for PREG_IR_DEC_BIT0_TIME
      #amlogic NEC remote
      factory_code    = 0x7f800001
      work_mode          = 0
      repeat_enable = 1
      repeat_delay = 40
      repeat_peroid = 39
      release_delay    =    121
      debug_enable     = 1
      fn_key_scancode    = 0x15
      left_key_scancode  = 0x1c
      right_key_scancode = 0x48
      up_key_scancode    = 0x44
      down_key_scancode  = 0x1d
      ok_key_scancode    = 0x5c
      pageup_key_scancode = 0x04
      pagedown_key_scancode = 0x1b
      #mouse_begin
      #       0 0x1c
      #       1 0x48
      #       2 0x44
      #       3 0x1d
      #mouse_end
      key_begin
          0x4d 113
          0x56 114
          0x4e 115
          0x25 105
          0x26 103
          0x27 106
          0x28 108
          0x0d 97
          0x1b 158
          0x53 102
          0x51 704
          0x49 139
      #   0x52 388
          0x31 2
          0x32 3
          0x33 4
          0x34 5
          0x35 6
          0x36 7
          0x37 8
          0x38 9
          0x39 10
          0x30 11
          0x58 389
          0x44 14
          0xbd 122
          0xbb 123
          0x09 393
          0x11 390
          0x54 391
          0x4f 392
      key_end
      repeat_key_begin
          0x4d 113
          0x56 114
          0x4e 115
          0x25 105
          0x26 103
          0x27 106
          0x28 108
          0x0d 28
          0x1b 158
          0x53 102
          0x51 704
          0x49 139
      #   0x52 388
          0x31 2
          0x32 3
          0x33 4
          0x34 5
          0x35 6
          0x36 7
          0x37 8
          0x38 9
          0x39 10
          0x30 11
          0x58 389
          0x44 111
          0xbd 122
          0xbb 123
          0x09 164
          0x11 390
          0x54 391
          0x4f 392
      repeat_key_end
