NEW - X8H-Plus 003 ARC beta in flashable zip format
I cannot keep running around trying to keep up on every box. So if there is some test firmware out there, provide me a direct link and I will see if I can whip up a flashable zip. I have not heard about a ARC beta.
At Minix we strive for exceptional detail and unparalleled quality in products and materials, standing firmly behind the enduring, premium quality of our products. Our products aspire for more through quality design that is built to last, and small but thoughtful details that make the biggest difference.
"This is a special release for users that are having audio drops when using with some amplifiers/older TVs,
which are not able to switch their audio clock automatically to match the video output,
the patch in this firmware is to force the audio clock to match with the video clock (ARC clock as well).
If you don't have audio drops, you don't have to try this beta, it's exactly the same as fw003 + Feb 7th update, apart from this patch"
Direct from the Minix site...
I'm connected to a Onkyo TX-NR3008 via HDMI and I'm getting audio drops... More so when you first start a movie/show and if you pause a video for more than a few seconds (drops the audio every 5 seconds or so for about a minute) and it doesn't matter if it is HD (1080p or 720p) or SD content..
Stay tuned. I will do this tonight and post the download link here.
ROM 003 ARC Patch in flashable ZIP format
OK as asked for.....
Here is the Minix X8-H PLUS 003 ROM with ARC patch in flashable ZIP format.
I provide NO instructions this time in the ZIP file due to time constraints. Use my instructions for flashing 003 flashable ZIP as they are the same.
So not to beg but if you found this useful, a donation is always appreciated
And thanks if you do donate!
_____________________________
As ALWAYS....... DO NOT just put this download on the SDcard! Unzip the download and extract the needed files for how you want to flash.
And as ALWAYS I set up this ZIP to erase all data so BACKUP!
ROM -> Minix X8-H PLUS (only) - 003 Stock ROM "WITH" ARC Audio PATCH in ZIP format - (490 megs)
BobLast edited by Finless; 03-06-2015, 14:23."Pzebacz im, bo nie wiedzą, co czynią"
I'm a little confused because the download link is the same as at http://www.freaktab.com/showthread.p...ble-ZIP-format and want to be sure not to use the beta?RK3288 Devices
- Overview BOX (LINK !)
There are currently 2093 users online. 3 members and 2090 guests.
