I have ordered an android TVBox, and while its on its way to home.....
As the Box has Giga-ethernet connection, and it will be next to the router, Im willing to connect it directly.
I had just installed on my phone the google TV remote, and i have seen that it looks the android tvbox in the same wifi.
"Android TV and this device need to be on the same Wi-Fi network"
I havent seen in any android device a double "interface" (wifi+ethernet) simulteneous.
Any way to have them both working at same time?
Will i have to use wifi only if i want to use the google remote???
Will it work if both devices are in the same "network" whatever the connectivity?
Any alternatives?
(im advancing problems.... maybe all runs smoothly
