I have the hdmi to the tv and the mini optical to my receiver and get picture but no sound. When I hook up my MX111 the same way it works perfectly. Tried all the settings in audio settings but no go. Mini optical is brand new. Most of the audio settings say hdmi for some reason. Anyone got this to work with optical as I don't have hdmi on my receiver?
Voyo Mini pc ........no sound
I just got the Voyo Mini PC and can't seem to get sound.
I have the hdmi to the tv and the mini optical to my receiver and get picture but no sound. When I hook up my MX111 the same way it works perfectly. Tried all the settings in audio settings but no go. Mini optical is brand new. Most of the audio settings say hdmi for some reason. Anyone got this to work with optical as I don't have hdmi on my receiver?Tags: None
Originally posted by trebor View PostThat looking OK,
Sound is turned up.
Maybe try another HDMI in port on the TV or another TV
Have you ever had sound.
Cheers
Originally posted by trebor View PostVoyo side is mini HDMI
You using an adapter to Convert
Or a Mini to Normal HDMI cable?
Running out of ideas
Cheers
Try This
Test if Windows thinks its making sound.
Open Playback Devices.
Click on Properties it will open another window, drag it to the side so you can see all the Playback device Window.(Sound)
If you click any place back in the Playback device window, it will error and plays a sound, as other window is open
Do you see the small graph next to your TV show a few lines every time you click.
If so Windows thinks it doing it just not been heard.
Also try
Device manager
Sound, etc
Uninstall sound drivers.
Shut down/restart see if drivers for sound can sort the problem out.
Hope its just a Driver up the creek problem
Cheers
I think it was at the pipo x7 where also exists the problem that the audio not works at every tv...RK3288 Devices
- Overview BOX (LINK !)
I received a PiPO X7 the other day and did the heat sink mods that were shown earlier with an ultra quiet fan. The video and internet works great...but "No Sound" what so ever on a brand new VIZIO P-Series 50". Funny, but also frustrating is that the PiPO X7 will transfer the sound via HDMI while using a 40" Philips & a 39" Vizeo with no problems. Then I can connect a windows 7 laptop to the new P series TV via HDMI port, and it works as well. So I believe the PiPO X7 is missing a driver to support some types of flat screen TV's as I have now seen being reported in other forums...any ideas?
There are currently 3505 users online. 1 members and 3504 guests.
