install Andriod back on my G Box Q
    Hi
    I flash openelec on my Matricom Q box Q. Now i wish to go back to Andriod, however i have tried using toothpick method to flash firmware, but working
    Any ideas? please help
    P
    Originally posted by partiksh View Post
    Hi
    P
    Try doing a hard reset in OpenELEC settings and then try the tooth pick method. Also, try placing your 3 files onto a USB pen drive and restore from that.
      Which three files? maybe that where im going wrong? only have firmware
        Is you firmware an img file or zip file?
          Firmware was a zip file
          I have just chatted to Matricom
          They have sent me a link for recovery.img
          And i have to copy this file and Firmware Zip file onto one SD that should work
          Thanks for you help as well
            Perhaps when you get your box restored back to Android from OpenELEC, you can post a description on how you did it, and where to get the correct roms. I am sure there will be others with the same hardware that would appreciated this information.
            thanks.
              recovery
              thanks.
              Hi
              Yes i managed to restore my G box Q back. Matricom support email me a recovery file, which i copied along with Firmware onto SD card and using toothpick method restore my G Box Q back to Andriod platform.
              If someone want recovery file please PM me as couldn't upload it here.
