teamviewer
Depending on the rom you use you have to load the correct qs add-on to view the screen. If your device is spoofing a device it will probably load the wrong one. Try the AOSP one and uninstall the other one. It is hit or miss if it works.
I have found it to work on
Stock cx919 4.2
Stock MK808B Plus 4.4
It didnt work on my
R89 110 but havent tried on Wasser yet
If you are on the same network you can use VNC.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
slip this in.
just to see if any of the boys can guide me on this.... i know its a kodi thing but i trust you lot here.... keep getting 2 errors on starting kodi.... found faults but dont know how to cure....cheers pinky...
- 12:58:42 T:956 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
- Error Type: <type 'exceptions.ValueError'>
- Error Contents: could not convert string to float:
- Traceback (most recent call last):
- File "C:\Users\hardpink1\AppData\Roaming\Kodi\addons\sc ript.grab.fanart\service.py", line 350, in <module>
- GrabFanartService().run()
- File "C:\Users\hardpink1\AppData\Roaming\Kodi\addons\sc ript.grab.fanart\service.py", line 138, in run
- self.refresh_prop = time() + float(utils.getSetting("refresh"))
- ValueError: could not convert string to float:
- -->End of Python script error report<--
- 12:58:43 T:2348 NOTICE: [MovieStorm] Subscription service starting...
- 12:58:43 T:8096 NOTICE: [TV4ME] Subscription service starting...
- 12:58:43 T:5908 NOTICE: -->Python Interpreter Initialized<--
- 12:58:43 T:5908 WARNING: CPythonInvoker(37): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
- 12:58:43 T:9204 NOTICE: StorageServer Module loaded RUN
- 12:58:43 T:9204 NOTICE: StorageClient-2.5.4 Starting server
- 12:58:43 T:4552 NOTICE: Stream All The Sources: Service: Installed Version: 0.0.68
- 12:58:43 T:7508 NOTICE: 1Channel: Service: Installed Version: 2.5.64
- 12:58:43 T:7508 NOTICE: 1Channel: Loading sqlite3 as DB engine
- 12:58:43 T:2196 NOTICE: Thread FileCache start, auto delete: false
- 12:58:43 T:7508 NOTICE: 1Channel: Service: Resetting...
- 12:58:43 T:3808 WARNING: XFILE::CSimpleFileCache::Close: failed to delete temporary file ""
- 12:58:43 T:7508 WARNING: Previous line repeats 1 times.
- 12:58:43 T:7508 NOTICE: 1Channel: Service: starting...
- 12:58:43 T:4552 NOTICE: Stream All The Sources: Service: starting...
- 12:58:43 T:4552 NOTICE: Stream All The Sources: Service: Resetting...
- 12:58:44 T:6048 WARNING: Previous line repeats 1 times.
- 12:58:44 T:6048 NOTICE: -->Python Interpreter Initialized<--
- 12:58:44 T:6716 NOTICE: Previous line repeats 2 times.
- 12:58:44 T:6716 NOTICE: 14
- 12:58:44 T:8700 NOTICE: Thread FileCache start, auto delete: false
- 12:58:44 T:3808 WARNING: XFILE::CSimpleFileCache::Close: failed to delete temporary file ""
- 12:58:44 T:8336 WARNING: Previous line repeats 3 times.
- 12:58:44 T:8336 NOTICE: Thread FileCache start, auto delete: false
- 12:58:45 T:3780 WARNING: Previous line repeats 1 times.
- 12:58:45 T:3780 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- Error Type: <type 'exceptions.ImportError'>
- Error Contents: No module named watchhistory
- File "C:\Users\hardpink1\AppData\Roaming\Kodi\addons\sc ript.module.watchhistory\default.py", line 22, in <module>
There are currently 1922 users online. 0 members and 1922 guests.
