problems with apps
    problems with apps
    hi kind of new to rooting as i have just installed finless flash on my device, ive noticed one thing where when i try to play angry birds star wars the game just blinks with a black screen and closes, any body else had this problem if so could you fix it and how?
    i've seen alot of people complaing about having problems with the same thing it's because they put updates on the apps . they work fine on ics and jellybean .
    freaktab art developer if you like my work please buy me a pepsi
      problem with angry birds starwars
      my sons Arnova running 2.1 rom installs the app but when it loads it gets a blank screen then flashes back to previous screen, he's so gutted he sat there installing an uninstalling and installing in the hope it might work for ages. He loved playing on his tablet, but doesnt seem to bothered with it now, anybody any ideas
      Cheers
      Harpo
        Cheers
        Harpo
        star wars angry birds will probably not work but if you can find older versions of other angry birds you should be fine
