How install custom recovery TWRP to Cube talk 9x
Check Lepi's video tutorial "Flash Recovery with SP FlashTool". You can find tutorial from here. Tutorials are also listed in Talk 9X info thead.
Originally posted by zeroonea View PostI open the flash tool, turn off the tablet, but when I put cable usb, It only display charge screen, nothing at all.
My computer already reconnigze my tablet
Driver installation
If you have not installed drivers then power off the Cube Talk 9x U65GT and connect to the PC. The PC should detect the U65GT and try to load in drivers, choose to locate the drivers yourself and browse to the Drivers Folder and install.
Check the "Installing MTK Drivers - Some Problems Solved" -thead also.
I try this and can install driver on windows 8.1 now
Go to Start - Then Command Prompt
Enter command "shutdown /r /o /f /t 00"
Click the "OK" button
System will restart to a "Choose an option" screen
Then select "Troubleshoot" from "Choose an option" screen
Then select "Advanced options" from "Troubleshoot" screen
Then select "Windows Startup Settings" from "Advanced options" screen
Click "Restart" button
System will restart to "Advanced Boot Options" screen
Select "Disable Driver Signature Enforcement"
Restart & install drivers...
You can also try this method. Worked for me!
First, make sure you are rooted. Second, make sure you have the latest Superuser and Superuser binary installed. Third go to the Playstore and install "Mobileuncle Tools". Fourth download TWRP recovery (from one of these posts - I recommend TWRP_2810_Lite) and put it (the recovery.img) in root of your sd card (I believe it is the internal one). Fifth, load up Mobileuncle Tools and go to "Recovery Update". That's it, no pc required.
Originally posted by Vohukain View PostThe PC should detect the U65GT and try to load in drivers...
My Cube is UG65GT16GB1426…. The ROM is the official one delivered with the Cube : V1.6_20140620. Debugging mode when USB is connected is ON. The computer runs Windows XP.
This looks great ! Can be done on the tablet alone. Siince it's a blind copy (byte for byte, including partition and formating date, etc.) I guess the format of the image is very important. I downloaded an image (listed in the recovery list post of the forum) but it's in bin format.
Does the recovery depend on the partition scheme of the tablet internal memory ? I read expressions like "CMW zip-file for 6Gb app space"…
Addtional question : do you know which is the exepected file system so that i can havt a look at its content before flashing it ?
There are currently 2187 users online. 1 members and 2186 guests.
