Does anyone have a working flash player installed and if you do can you explain how you did it?
Flash Player Nextbook 8 (NX785QC8G)
I have twrp, 2g patch and the modified ROM by shaunmt installed. It took me a while to get it all to work. Thank goodness I did a full backup after installing twrp as I needed it. Anyway .... no matter what I do I can not get flash to work in maxthon, firefox or dolphin browsers? I have tried about 5 different versions of flash for 4.4.2 with no luck. I had to download puffin browser as you don't need a flash player installed.
Does anyone have a working flash player installed and if you do can you explain how you did it?Tags: None
Originally posted by doebert View PostI have twrp, 2g patch and the modified ROM by shaunmt installed. It took me a while to get it all to work. Thank goodness I did a full backup after installing twrp as I needed it. Anyway .... no matter what I do I can not get flash to work in maxthon, firefox or dolphin browsers? I have tried about 5 different versions of flash for 4.4.2 with no luck. I had to download puffin browser as you don't need a flash player installed.
I don't recall, how I set it up, but I think Dolphin provides its own modified flash version... It's either in settings or add-ons or extensions.... maybe it requires or is part of the dolphin jet pack?
it also has to be enabled in the dolphin and/or jetpack settings after everything is installed.
Even then, results may vary from one website to another...
I'd help more, but I'm currently using my NX785QC8G to debug an OmniRom build.... SURPRISE!
ShaunMTFreaktab Rom Developer
Originally posted by shaunmony90090Flash works for me in Dolphin (the only browser I ever use for anything on Android).
ShaunMT
Here is what I did as it may help someone in the future:
1- remove any flash installed
2- install dolphin browser
3a- install jetpack
3b- open jetpack and click on link for flash download
4- install flash
5- open dolphin and make sure jet pack is enabled and flash is set to on demand or always on
This flash only works in dolphin
Great to hear your working on OmniRom......always enjoy your work
Imao you are the best
There are currently 3468 users online. 1 members and 3467 guests.
