Cube Talk 9X [U65GT] - "Can't find SD card" problem
    Hello,
    I have a new 16GB White Talk 9x, I am on stock ROM but I have rooted it this way : http://www.freaktab.com/showthread.p...l=1#post213748
    Something is wrong with the SD card access, I couldn't save the IMEI with MobileUncle Tools :
    The titanium backup has problems also : "Backup failed : Insufficient storage space."
    Is there any solution for this ?
    I have tried to edit the platform.xml but it doesn't solved the problem.
    Thank You.
    platform.xml modification
    This was the platform.xml modification what I tried :http://www.freaktab.com/showthread.p...l=1#post218919
    There is an "extsdcardfix.zip" in this old post (CWM zip fix for read only external sd card) : http://www.freaktab.com/showthread.p...050#post201050
    I dont know that it was a solution for the same problem, and should I try it with my new 2.0 stock rom from stock recovery ?
    Or should I move to CWM or TWRP before I try it ? It says its a CWM zip, does it working from TWRP also ?
      SOLVED !
      Problem Solved !
      First I have upgraded the SuperSu to the latest 2.46 version with TWRP, but I am almost sure that it is not neccessary.
      In SuperSu settings, I had to disable the "Mount namespace separation" setting.
      Now it seems that everything is working properly.
        Originally posted by akarki View Post
        Problem Solved !
        This is great to know as I will be getting a SD card shortly for my cube..thanks for showing this.
