Help: Cube U65GT SD card fix ?!
    Hi, I have Cube with Lepi rom last version update, but I have problem with extSD permision.
    Read is OK Write from external apps is denied
    I see this issue with Titanium Bakup and other program for recording screen.
    Is there any way to fix SD correct because I try manual to edit files and before that I try with apps from market, but no succes
    Please help me if have any chance to repair this !
    Thank you !
    Similar problem
    Hello,
    I think it's the same problem as mine : http://www.freaktab.com/showthread.p...d-quot-problem
    Have you tried to save the IMEI with MobileUncle Tools ?
    Just to see that you get the "Can't find SD card" message also.
      You are right
      Yes you are right !
      I try with mobileuncle and this is the answer Can't find SD.
      I try also with my Quad-Core phone amd situation is same.
      The problem is in KitKat version of android, but in market has sd fix who don't work with my phone and tablet
      Please if anybody fix this problem to help us!
        My problem was different, not the KitKat SD block issue.
        I have solved mine, as I wrote it in the other thread : http://www.freaktab.com/showthread.p...l=1#post290076
          Link
          I must try your solution. Please give me a link of supersu version. Thank u!
            First I changed the stock recovery to Lepi's "TWRP_2.8.5.0_mod_Lepi.rar only for SP Flashtool!" https://yadi.sk/d/wexl8of_egGRc (naturally with SP Flashtool )
            As you can see in this video, which made by Lepi also (thanks for him): https://yadi.sk/i/Qs4ewCc8XyWTb
            After that I tried to uninstall the old SuperSu, but it was not easy to get rid of it. I tried to uninstall several different ways, and reinstall several times, from the PlayStore https://play.google.com/store/apps/d....supersu&hl=en , and with TWRP http://download.chainfire.eu/696/Sup...erSU-v2.46.zip also, but whenever I rebooted the tablet the old SuperSu was there everytime.
            Finally I started to install it from Play Store but after it the program asked me that it can bee updated with TWRP if I want (or something like this)? I pressed the button that try to install through TWRP, although it say something that not sure in success. After that the tablet restarted to TWRP, installed the new SuperSu automatically and the tablet restarted again, and finally the new v2.46 SuperSu was there.
            But as I wrote in my topic I'm not sure that it was even necessary, because I think that to uncheck the "Mount namespace separation" is enough, but I'm not sure that this option was there in the old SuperSu version. But if its there in your version, first just try to switch it off, and reboot the tablet.
