What benefits would I have if I installed openelec only? Would I still be able to do everything I do know including power down via remote?
MXIII Android or openelec?
I have a MXIII 2G/8G running android kodi and works quite well. Shut down from kodi is slow but that's my only complaint. It runs my bluray iso's and dvd iso's from within kodi great, as well as running add ons, ect.
What benefits would I have if I installed openelec only? Would I still be able to do everything I do know including power down via remote?Last edited by darkmast3r; 12 March 2015, 16:39.Tags: None
Originally posted by darkmast3r View Postwow - over 80 views and no replies. Can no one advise me if it's worth flashing my box with openelec?
The flip side to this of course is that you'd have to give up running Android APKs. Since OpenELEC is pretty much ARM Linux, so no Games, Emulators (as such..) or other Apps like say Showbox for example.
Of course with Sat>IP on the rise... (Again it would help if you came here from a VDR perspective...), you really don't need OpenELEC a such, since XBMC / Kodi, can do this much already. e.g. Simple IPTV Protocol.
Which Ones better kinda depends upon what your exact needs are.
Since I'm more of a Google Music fanboi, and love my Maryland Radio streaming Apps... I tend to side, on the side of Android for now. Plus having a DVB-C (Cable) > IP(TV) in the form of a Fritzbox Repeater to at least cover the FTA Channels. Which is all I need for at the Moment. I'm not exactly feeling the need to push on just yet.
That and the constanly broken AP-6181 WI-Fi Drivers I'm always having deal with in OpenELEC. I'm not going to say its still a valid argument. As I wouldn't know it. I haven't dealt with OpenELEC in some time now. 'cause I value Google Music more so then testing a possibly broken OpenELEC, and so wasting another "Device" on Google Play.
FYI if you are a Google Music user on the MXIII (or possibly any other Android TV Box...)
Every time you flush, your Data Partition, you are in effect creating a new device. (note you can only have up to 10 Devices connected to any GMusic Account at any One time. The kick to the crotch however comes in the form that since last August. You can now only deactivate ONLY FOUR DEVICES with-in a 365 Day Period!)
Upshot is if you have that "Testing Bug" then DO NOT INSTALL GOOGLE PLAY MUSIC!
Thanks for the response Ichijoe. I did decide to give it a go but blu ray playback was pretty bad for some reason. Very slow using hardware or software enabled. I then tried finless 2.1 but found my memory showing 55/60% at idle. I did a fresh install of the stock firmware and everything is running well again.
I'm wondering how blu ray playback would be on a chrome box.
Originally posted by darkmast3r View PostThanks for the response Ichijoe. I did decide to give it a go but blu ray playback was pretty bad for some reason. Very slow using hardware or software enabled. I then tried finless 2.1 but found my memory showing 55/60% at idle. I did a fresh install of the stock firmware and everything is running well again.
Sadly I don't have any Blueray rips to test as such. Not actually owning any BlueRay or a Player with which to rip them with.
But, as to DTS, and DD5.1 (as thats all my Decoder ~ca 2004), is capable of. I find that the SPDIF.-Out is more then enough to get that much working. Otherwise I kinda fail to see the point in Software Decoding sans the Speakers. Otherwise I'm sure that the LPCM though the HDMI Cable to the Decoder would work just as well...
On that topic, did you remember to set the Passthough Option in XBMC/Kodi?
Otherwise it cant pass the Signal though to the Decoder to be decoded... duh!
Hi Giglife. I flashed with openelec from here http://amlinux.ru/image/5.0.3/, also tried 5.0.5 but blu ray playback was really bad. Then tried bob's finless 2.1 from this thread which showed the high memory but looking at the posts in that thread it seems I am not the only one with that issue.
Regarding the chrome box I may have to search around for my answer. It does do digital audio from hdmi, that I do know, I just want to be able to play all my formats without issues or frame problems.
There are currently 1356 users online. 0 members and 1356 guests.
