Cube Talk 9X [U65GT] 32GB
    Hi to all I am an new owner of a 9x 32GB Black.
    I start reading all the posts concerning this tablet and I am very confused
    I want to install for the begining TWRP recovery and root, I know how to work SP flash tool and MTK Droidtools, I had and a 8389 device, and I had also all the drivers installed.
    I also want to increase the internal space to 10 -12GB, but I see some links are not for 8392 but for 65XX series
    Please can anyone point me to a link to those 3 mods
    I don't want to do something wrong
    Thanks in advance
    You can root your Talk 9X withmmrrdd's root file via stock recovery.
    You can resize internal app space up to 6Gb with Brian's patches (EBR1 and EBR2) for sure. Also you can use MT6592 patches (14Gb, 16Gb, 20Gb, 27Gb) from here and they should be working with Talk 9X also. So maybe you should try to use 14Gb patch (EBR1 and EBR2).
    You have to flash those patches via SP Flash Tool. After you have flashed EBR files you can flash TWRP via SP Flash Tool or at the same time with EBR files.
      You have to flash those patches via SP Flash Tool. First of all you need stock recovery. So don't change your recovery to TWRP before expanding your app space. After you have flashed EBR files you can flash TWRP via SP Flash Tool.
      Thanks my friend for the answer please to understand you say "You have to flash those patches via SP Flash Tool .First of all you need stock recovery"
      Why I need stock recovery, I will make flashing using sp flash tools another is, folders that are the size patches has and a scatter file inside shall I use this scatter with SP Flashtool or the scatter of my my Cube ( those patches from http://forum.zopomobileshop.com are not for Cube.)
      Second the recoveries is mentioned to flash trough TWRP or CWM , Can I extract the zip, take the recovery.img and flash it using SP Flashtool? or mobileuncle if I had managed to root it first?
      So first repartition after root the recovery?
      Thanks again
        Thanks again
        Sorry, I was talking nonsense. Too little sleep...
        You are right! You don't need stock recovery for EBR files. So first root your tablet any way you want (check here). Then flash EBR files with SP Flash Tool and use your own scatter file for Talk 9X. Those MT6592 patches aren't made for Talk 9X but however they should work with Talk 9X also. You can flash the TWRP recovery with SP Flash Tool but CWM must be flashed via TWRP (or another custom recovery). Check Lepi's video guide for flashing TWRP from here. For example Lepi's 2810 TWRP is in ".img" format so you can flash it via SP Flash Tool. Hope this helps and sorry for earlier...
          You must not ask for sorry, my sorry for asking so many questions
          A last question ... I hope
          So
          First step through stock recovery rooting with withmmrrdd's root file via stock recovery
          Second TWRP recovery using sp flash tools extracting the recovery.img inside the lepi's TWRP 2810
          This is the most importand to me I have Kitkat 4.4.2 in the http://forum.zopomobileshop.com/foru...age=1#pid12286 I see that all links in the start are not mentioned for what OS it will be, but at the end it is writtenE) Section Primary partition for smartphone with new O. S. "KITKAT"but there the there is not 32GB model it has only4) New Editing Primary Partition to 13,19Gb (max possible on octa core) for KitKat O.S. (Mtk 6592 - 16gb). This is the only one for kitkat and MTK6592, mine is 32GB I want to split is about in half, half internal memory half internal SD. Is this file ok or I will make a brick?
          Is there anyone that had used this file to repartition 32GB kitkat Black model?
          And when I will do this data on internal memory and internal SD will be erased?
          Thanks again
            Thanks in advance
            Hi!
            Can you post the your scatter file?
            Also, could you please post the result of CPU-Z on your U65GT.
            I would like to compare them with mine, as I am not sure I am doing things right.
            Thank you in advance
              Originally posted by SolGarlic View Post
              Hi!
              My friend I had not received my tablet yet I read to be ready when I have it at my hands then I will sent you the result.
                So
                Thanks again
                Use this one:
                http://www.4shared.com/zip/OdVk0FR1ba/Ebr_13gb_kitkat.html
                You will lose all data when increasing app space because you have to format partition when resizing.
                  Use this one:
                  Thanks my friend for your help
                    Another simple question please ( I ask too much.... )
                    On a Cube out of the box , can using SP Flash Tools to flash TWRP recovery and EBR1 and EBR2, at once, and after through TWRP install a Lepi's rooted firmware?
                    Or I have to enable usb debugging, and root it first using stock recovery using themmrrdd way ?
                    Thanks in advance
                      I bought this baby today for $ 185.00 included DHL shipping (on sale for today only at Aliexpress!) for my sisters-in-law and can't wait to see how it's performing.
                      Sent from my Samsung Galaxy Tab Pro 10.1
                        Thanks in advance
                        The answer of your first question is YES.
                        USB debugging and rooting is not necessary: Lepi's ROM is already rooted.
                          Fantastic price!
                          The only problem is that through DHL you will pay custom duties for sure!
                            Originally posted by giouncino View Post
                            Fantastic price!
                            Never ask for courrier DHL, ups etc for importing items outside Europe, wait more but ask for standard delivery 90% you will not pay customs that way. Customs are at least 30% if the declared value is over 20$
                              In Italy custom duties are 22%+5€ but generally only whn value is over 50€ and yes: courier must declare values, then with them duties are ALWAYS present!
