i Need your help cause i don't know which Revision is my Box.
It's called "Quad Core A9 XBMC Android 4.2 TV Box Mini PC Smart TV 8GB WLAN 1.8GHz CS918".
I attached all Information a have of my Box.
My Question is which Revision do i have and for example which Version+kernel of the "wasser Firmware" i have to load und with which tool i can Flash the firmwares correctly?
take care & thx4help
Vanni.Violett
