Make any controller compatible with Android Tv
Is there a controller I can buy that can work without doing all that? I want to play games like mortal Kombat x , gsr racing 2, FIFA 16 etc on my android tv box. I have Xbox wireless controller but does not work. It won't sync with receiver. Thanks I'm just new to android boxes. My box is rooted as well.
Originally posted by Zeka View PostAnyone have a PS3 Dualshock .kl file? For me its Vendor_054c_Product_0268.kl, it is already existent on my MXQ 4K, but worked only partial. I try made up my own, but again some buttons not worked as expected. Thanks in advance.
Can I use this USB Joystick Controller ( https://www.icrfq.com/search/?keywor...3&searchtype=0 ) on my Nvidia Shield Pro? If yes, could you please advice me how can I use this controller? Thanks.
Originally posted by Brandon0679 View PostCan I use this USB Joystick Controller ( https://www.icrfq.com/search/?keywor...3&searchtype=0 ) on my Nvidia Shield Pro? If yes, could you please advice me how can I use this controller? Thanks.
not sure , but i think well , does the Controller support Android native ???
good luck / gefattern
i followed this guide and did all of it
created the new vendor file
used the keymap apk
i also had look at the generic file that was already there and the button mappings were the same as what they should be.
i still created my vendor file and saved it as shown in instructions.
on the keymap apk it shows my gamepad directional buttons as all 0
the axis controls are in the vendor file though
everyhting still works though as it did before and no direction buttons work.
the only thing i cant see that is same as in this post is that i dont get the permission numberYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
There are currently 1833 users online. 2 members and 1831 guests.
