Ugoos ut3 constant reset and powering off
I had this unit for awhile now but it's starting to freeze up, and just reset itself, some days more than others. Sometimes it's real hard to watch a show or movie without it resetting. Anyone point me in the right direction? I'm thinking about picking up a minix x8-h today because I'm tired of this...Tags: None
Had you ever tried to use another 5V/3A psu?RK3288 Devices
- Overview BOX (LINK !)
Maybe, who knows... often the PSU is the problem if you have freezes and reboots...RK3288 Devices
I had some similar issue.
It was probably the power adapter. indead.
Now, my box UT3 look like dead. no power, no blue light, nothing on the TV.
I'm searching to buy a new device( 30$ to repair it + shipment cost, no was).
I still have an M8 (in my bead room) and a Western Digital TV (as backup, in the leaving room).
I don't know what to buy.
I'll see. I searching how to open my box to check.
Almost any 5vdc 2.5 amp+, switching type, power supply with the correct size plug and TIP POLARITY should be sutible for testing basic functions. If using a smaller than 3 amp supply, disconnect USB devices.
I have an old PC power supply, with casual modifications, I think it would work for testing. A basic understanding of electronics/electricity required for that.
Good luck
Originally posted by yeroc1982 View PostAnother m8?
Regarding power supplies, the UT3 or other sensitive electronics;
I doubt many think to use a line conditioner or quality surge suppressor/UPS on these boxes.
I wonder how many product's lives are shortened by this over site.
Incoming A/C(wall outlet), can be pretty nasty and inconsistent, and really bad in some areas.
I just picked up an HD TV from someone. The set was damaged by a spike during a storm.
I fixed it and now I have a working free TV.
I'll bet many devices are trashed/replaced by similar events.
It is not always the device makers fault.
Just sayin'.Last edited by RISCy Dude; 15 March 2015, 02:22.
Originally posted by yeroc1982 View PostI had this unit for awhile now but it's starting to freeze up, and just reset itself, some days more than others. Sometimes it's real hard to watch a show or movie without it resetting. Anyone point me in the right direction? I'm thinking about picking up a minix x8-h today because I'm tired of this...Originally posted by yeroc1982 View PostIt powers on fine and all, just lots of random resets
Any idea what indicated temps are before failure(freeze, reset)?
Originally posted by tempo22 View PostMine has a fan, and the temp was probly not high since the fan wasn't even on when it did. I think it's more a software issue.
In my case, i had the problem after watching a movie, i was browsing available content and xmbc restarted serveral time, then i had the ugoos bootscreen of loading
Also, you mentioned XBMC. Are you using XBMC or SPMC?
There are currently 1974 users online. 2 members and 1972 guests.
