Vigica C90s S805 DVB-S2 finally available
    after the VENZ K1, here is the VIGICA C90S S805 DVB-S2, it seems to be a very nice box, knowing that VIGICA is the only that support to some extend Linux DVB-API
    VIGICA C90S
    Greetings rexis:
    I already bought mine and I am waiting for me to arrive. When have I'll give my impressions.
    http://www.aliexpress.com/item/2015-...298531011.html
      thx, I'm looking forward to it
      personnaly I'm waiting to an OPENELEC port on this device or the VENZ K1
        What will openelec give you over keeping android and using Kodi
          there is already openelec for vigica c70s , dont know if it works for c90s
            How doe's this stack up to wetek play in specs, AS tried competition & tried to order from wetek and cannot get one. Nobody knows who won competition, and wetek keep saying sold out for the last 7 day
            none of these good for wetek.
            http://www.aliexpress.com/item/2015-...298531011.html[/QUOTE]
              there is also Venz K1
              similar to c90s except 4 usb port and real spdif port
                Vigica c90s new firmware is available. Can root through the factory update
                  Root http://4pda.ru/pages/go/?u=http%3A%2...oot_update.zip
                    The new firmware is available here
                      new launcher, new kodi
                        yes, New firmware, support Russian, turkish, polish language, and Kodi 14.2. Come on try
                          Do you have a link to the firmware for the newer boxes with sno higher than VGC810150420**** i have a problem with th tuner thanks
                            Having some real issues with th dvb TV on this box unpacked 2 so far and tuner is ok for a while then you start getting signal dropout and pic breakup. Anybody else have this issue.
                              Yes ,me , i have this issue too
