making a copy of a dal boot Meego
    Hi all
    I am trying to copy my dual boot ( Windows 8.1 and Ubuntu 14.10 ) to another Meego
    On the original Meego I have
    - new BIOS with auto start up
    - Windows 8.1
    - ubuntu 14.10 that also auto boots ( tweaked GRUB a little bit )
    - I get 2 entries in the bios boot menu
    On the second Meego I have
    - New Bios with auto start up
    - windows 8.1
    I make a copy of the original with dd if=/dev/mmcblk0 .....
    Put that on the second Meego, I get boot problems
    It doesn't boot at all from Ubuntu and windows needs to repair it self ( that succeeds )
    If I then copy in mmcblk0p1/EFI/ubuntu the grubia32.efi over grubx64.efi it starts working
    but it seems like that after one auto boot it will hang on boot. If I then go to the other entry
    of ubuntu in the bios boot manager that one starts also only ones.
    Doe anybody have any idea what can be wrong ???
    A number of people what this meego with my setup, but at the moment
    I can' t provide, because of this problem ( the people that need to install can't go throug the
    complete process of installing it from scratch )
    I don't know what you had done, but why don't you try to use e.g. clonezilla or something like that? http://clonezilla.org/
    Maybe, before you write the backup, first you have to update the bios?
    BTW: please remember that you are not allowed to post any backups of the windows at FreakTab...
    RK3288 Devices
    - Overview BOX (LINK !)
      Do yo mean, that there are configurations in the bios area, that are related to the bootable systems on the meego? I already put the same auto boot bios on both meego's.
      I was not planning to do so. The target group is in RC aircraft's :-)
      DB,
        I don't know, but I would do it this way only to be sure source and destination are identical...
        RK3288 Devices
          Exactly let me see if I can make a Clonezilla USB Stick that can Boot in this and make Backup of it.
