I would like to share with you.
Android Minix buy, BIOS update, and install windows 32bit
- Download a bios file
- download the rufus program
- Start the rufus
- Partition scheme and target system type: MBR partition scheme for UEFI computer
- Create bootable disk using: NO (remove the checkmark)
- Start
When finished, the downloaded BIOS file to unzip, and copy it to the root on your memory stick the EFI folder.
To set the BIOS to the EFI shell script to boot.
When done, auto turn off the device. (indicated by the LED)
The script will be saved in the original BIOS on memory stick!
Rufus program help can install Windows 8.1 32bit operating system, the USB stick can only be fat32 filesystem!
Just be careful!
Sorry my bad english, I hope you understand
