Help just broke my Pipo
Hi there that's bad luck did you use higher volts or higher amps not that it matters now im just interested & another thing my pipo PCB is different to yours
Normally higher amps shouldn't be a problem except there already exists a problem at the pcb...
I think v1_2 vs. v1_3 pcb version...RK3288 Devices
- Overview BOX (LINK !)
Like no spam said higher AMP's should not of been the problem. If your soldering skills are good it may be fixable if we can find out what chip it is you have fried that's why I checked my pcb.
Can you read whats on the fried chip
Yes my PCB is v1_2Last edited by blinkone; 15 March 2015, 23:15.Please consider making a Donation to freakTab
Originally posted by loko View PostCan you please post a picture of the power supply you used?
It would be nice to know its exact specifications to avoid using such a device.
A close and clear picture of the label is definitely needed, but other pictures are also welcome.This is the offender.Any ideas what part of my board is gone?
Originally posted by bozharry View Post[ATTACH=CONFIG]10839[/ATTACH]This is the offender.Any ideas what part of my board is gone?
Sorry for your bad experience.
I have only had problems with the DC power plus size ... nothing serious.Last edited by geppetto61; 24 March 2015, 19:33.With the kindest regards, geppo
Originally posted by oversx View Post12V? Voltage should be 5V! It will be destroyed complete
The Pipo x7 is 12v not 5vPlease consider making a Donation to freakTab
There are currently 3788 users online. 1 members and 3787 guests.
