Hi guys, I am using a R28 Pro. I connected USB thumbdrive to store movies for playback. When I deleted the movie folders , they will reappear after some time. I tried formatting the thumbdrive on a PC and also use a new thumbdrive, but the deleted folders will also appear on the new thumbdrive. Any one knows whats the problem? Thanks!
Deleted Folders on USB drive keep reappearing
But you only talk about the folder?
I'm not sure, but the first idea I get is, that xbmc/kodi maybe recreates the folder because of it's databaseRK3288 Devices
- Overview BOX (LINK !)
Originally posted by RISCy Dude View PostWhat happens if you rename the folder instead of deleting it. Then if the original named folder shows up again and the renamed folder is still there, I'd think something is creating it, like mxplayer.
[QUOTE=bluesmanuk;293061]Are the files and folders synced to some kind of cloud storage that is putting them back as part of a two way sync?[/QUOTe
No I'm not sync to any cloud storage.. Think I just leave it as that. Another question, I can't play 1080p videos on YouTube app.max option is 720p, any solution to tat?
There are currently 1474 users online. 5 members and 1469 guests.
