I have an Arabic Iptv box which uses an A20 dual Allwinners chipset, picture of the box
The applications kept closing automatically so i thought if i'd update it then the problem would be fixed, however, once updated the box starts up with a red rectangle as you can see in the picture below.
So I need the to find the firmware for it to get it back and running,
I looked at few threads on here but wasn't sure if the firmware was compatible
here's an image of the system info that i got before messing the box up
Also it has 1gb ram and 4gb storage
THe box doesn't have an sd card slot only two usb ports and i have no way to enter the recovery system, that I know of.
Here a picture of the board and the back
I tried connecting the box to the computer using usb-to-usb cable howver this only gives the box power doesn't see it. But i came across this guide where i need to press on two legs on the motherboard and it shows up on the pc. Here's the pictures of the guides:
