Please Help with A20 probably bricked
    hello to the community.
    i got this box:
    i tried to flash this firmware:
    Justop_Dbox_One_8GB_A20_P2_rooted_xbmc_20140402
    but it looks like my box is bricked now.
    blue led doesn't flash anymore.
    i burned this firmware A20_sun7i_android_sugar-A10_8188eus_20140402.img
    to SD CARD but still no luck
    can you please help me?
    i need to know which procedure i have to follow and which firmware to unblock my box
    thnx in advance
    i got this box:
    thnx in advance
    HI I think i can help you i had a similar problem but took me ages to figure it out.
    First you specs on that box is similar to mine and the firmware you flashed is not compatible to your box.
    First thing first i need you to open your box and send me pictures of the board take picture of the whole board and then zoom in on a few places.
    Also do you have a usb to usb connector? If not get one then we can proceed!!
      thnx for your answer Faddys i already found the right firmware for my box. if you want i can post the link: https://mega.co.nz/#!9xswhDIS!fwKsNq...uvNwStWh9k6uUA
      Then just a couple infos about my box. you can find detailed infos here: http://linux-sunxi.org/Sunchip_SDK-758
      as you can see by the pics there's no OTG port so if you mean that by saying USB to USB port there's any into my box.
      if you have any other ROM to test for my box please advice me about it
      thnx again
        thnx again
        That's the same firmware that i have lol
        You have two full size usb ports right? All you need is to order something like this : http://www.amazon.co.uk/USB-Male-2m-.../dp/B0018I97M0
        Then i can show how i flashed the firmware
          i have that cable. pls tell me how can i dump my actual firmware so i can have a backup.thnx
