3 M8 Amlogic S802 devices without ethernet network!
    Like the title says, I got 3 m8 boxes with no ethernet connect after flashing. I tried justme, stane1983, codesnake's roms without any succes. Also stock roms tested without any succes. If i check/uncheck the box, you see no ip only "disconnected".
    Can someone tell me what I do wrong?
    regards,
    Snotzilla
    Originally posted by snotzilla View Post
    regards,
    Snotzilla
    Hi you are in the wrong thread are your box's round or square & I will move you to the right place where you should get more help.
    Blinkone
      square
      thnx!
        square
        thnx!
        try this http://www.freaktab.com/showthread.p...l=1#post191442
        do you even get any lights blinking on the back ? you may even have faulty Ethernet ports
        Bugs are Sons of Glitches!
        JustMe
          Cable and port must be good, because with static ip I got internet, till i reboot then the box lose his settings.
            seem like an issue with the firmware
            JustMe
              Tried more then 10 firmwares without any succes!
              is there any solution to fix it?
              To make a boot.bin with mac or something els?
                can you take picture inside of your box pcb want to see what chip you have. the firmware you posted has no ethernet on my original m8 I tested it.
                JustMe
                  it looks like a s802b device
                    [ATTACH=CONFIG]10887[/ATTACH]
                    sorry m8 can you look under the circuit board and tell me if its ap6330?, I will upload firmware and post you a link i have modded it and ethernet now works with my original m8 box
                    JustMe
                      yes, its a ap6330 circuit, can you tell me what the different is with the other box (firmware)?
                      thanks for your time and your great work!
                        back in 20min when upload is finished
                        added to post to stop PM's:
                        its a stocker with the ethernet fix only, i have stripped all preinstall apps and only left aptoide to save bandwidth. and no tweaks or performances done
                        JustMe
                          added its a stocker with the ethernet fix only, i have stripped all preinstall apps and only left aptoide to save bandwidth.
                          thnx, I will give it a try!
                            still the same problem
                            ethernet disconnected!
                              with openelec via ssh
                              ifconfig eth0 hw ether XX:XX:XX:XX:XX:XX
                              this commando works, till i reboot (then i can use internet without problems)
                              there are problems with network config.
                              after reboot it lose all network settings.
