Other box firmwares
I tried both (mo's only for a short time) and both are booting and also working, but I think (not sure because I don't use it) the IR wouldn't work (and also didn't test the lan/wifi which I think will work)... also you will loose the ugoos specific settings (also fan support)...
BTW: I'm using wasser 2.0.6 booting from SD card...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by mo123There is now also Lubuntu from Firefly that boot from SD.
Maybe you will find it useful.
http://pan.baidu.com/s/1bnaYRyZ
Which instructions? How to download?
[下载(229.3M)] -> [普通下载]
And I think you have to use Win32DiskImager to burn it to SD http://sourceforge.net/projects/win3...files/Archive/ (or using dd at Linux)...RK3288 Devices
Originally posted by no_spam_for_me View PostWhich instructions? How to download?
Sent from my HTC One using Tapatalk
Ahhh, OK, good to know, THXRK3288 Devices
Originally posted by mo123No, you use Rockchip SD Card Tool to write to an SD Card.
Here are the instructions
http://wiki.t-firefly.com/index.php/...oid_from_sd/enfairly fast until you try video playback.
Hello Mo123
today I tried to load a newer Firefly-Ubuntu <Firefly-RK3288_MainlineKernel-Ubuntu14.04_201503191033.img (277.4 MiB - 19.03.2015)> image with MainlineKernel.
Unfortunately I always got an issue (this program breaks/exits completely under Win7) when I want to load this file to my sdcard with your mentioned RK-Tool (SD_Firmware_Tool.exe).
I checked with the file you mentioned before there are no problems at all - flashing and booting with no issues.
Shouldn't I use this tool for this file?
Maybe you know a little bit more about this image.
Thanx Mo123
I wanted to try this ROM, but if I have to flash it to emmc I will distroy my actuel version, which don't runs bad at the moment.
Regarding sound I have bought externel sound-system. Now for me there is no urgent need to compile the kernel because of this.
But if you have an idea to get 32bit/pixel screen resolution I'll go for it, try to compile the kernel if necessary.
Do you have any info's and solutions regarding this topic - this will be great.
Sam has done it, in his ubuntu-software, also it should be possible.
Best regards
Can only flash it to internal EMMC with AndroidTool v2.3
You also have to compile a new kernel for your sound settings etc.
You can also try to use this way http://freaktab.com/forum/tv-player-...y-to-dual-boot
but (because I don't know this img) you maybe also have to extract the kernel (and resource) from the boot (it it also includes these two parts) and if I'm not wrong you have to use the boot-linux.img (contains a minimum intramfs without rknand) from linuxium and maybe have to label the RFS with "linuxroot"...
(Sometimes ago I tried to use it with ugoos linux (0.2.x) but find no way to get the RFS mounted)...
Have a look at the "create-linux-sdcard"...Last edited by no_spam_for_me; 30 March 2015, 13:40.RK3288 Devices
Originally posted by endera View Postis there any progress ?
Windows 10 for RK3288. ??????
Windows 10 should also be available in June or before end of July.
There are currently 2213 users online. 2 members and 2211 guests.
