a Pipo M6 pro (no 3G) is on its way and i have a view questions.
First i need to say that i have not much Android experience so please bear with me.
First question is what ROM is the best when it comes to speed, stability and everything working?
I was hoping for something like CyanogenMod or OmniROM without all the Google stuff like Chrome, Gmail, Google Contacts, Google Calendar, Google Play Store. Something like that out there?
The other question is if all the ROMs support exFAT for the SD-Card?
Nowhere i can see what Android version is in the ROMs?
No change log or release notes?
A build date of the ROM in the filename and thread also would be nice...
The exFAT SD-Card question looks like is obsolete?
Android has no problems with NTFS right?
Ok, to answer my own question and maybe it helps others who are new here.
After reading the whole threads: The Project M6 Pro is the newer ROM.
When it comes to NTFS/exFAT i'm still not sure what to use.
There is no clear answer what a Tab supports. I thought it's an Android thing but it's the manufacturer who decides what
drivers they put in.
The RileyROM 1.8 was the last ROM developed from Pipo's last factory firmware release.
Since then, our Freaktab team was lucky enough to have Pipo share the sources and we built our own ROM. Maakie furnished the kernel. While my ROM was very good, the Freaktab ROM solved a few leftover little problems.
Results may very, though. That's why we still have both available for download.
Randy Freaktab Developer, Product Reviewer, Moderator and "Flashaholic". Read my BIO Here
Be sure to donate to support Freaktab.com. If any of my development work makes a positive difference for you, please make a donation to support future RileyROM's. Donate here
