It works fine using XBMC and it's addons, but Netflix quality was very bad.
Read online that Netflix won't allow HD playback on non sanctioned hd devices. When I saw that the finless 1.1 ROM spoof the Nexus 10 to make the device compatible with more app on the play store, I had hope it would make Netflix works in HD afterward. It did not.
What would you consider the best bang for your buck to play Netflix in HD, use XBMC and be able to control the device as well as the TV with the same remote?
