New Firmware, amlogic M8 S802!
Originally posted by snotzilla View Postit is for a amlogic m8 device, but again try at your own risk!
Could you add what device the firmware is for in the title please
Thank youPlease consider making a Donation to freakTab
Originally posted by warlock09 View PostM8
Pcb no. V0.92 and M8N pcb no. V1.0..?? Will these two boxes be compatible to the said firmware u posted??THANKS
check here http://www.freaktab.com/showthread.p...l=1#post292136
it just bare rom I have fixed no apps apart from google play and aptoide to save on bandwidth its basically a stocker with only fixing the no ethernet issueBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postcheck here http://www.freaktab.com/showthread.p...l=1#post292136
Apart from ethernet what issue is still on this rom??
Originally posted by warlock09 View PostYou mentioned its only for original M8?how about the M8N?would it work..so this rom has the issue of ethernet and wifi disconnecting??thanks[emoji1] [emoji106] [emoji106]
maybe you can take the time and test it. I have other works in progress to really worry about this rom.Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postas mentioned all I did is fix the Ethernet issue of the stock rom(Ethernet disconnected as you could not connect via ethernet) and re uploaded minus the apps.
seems like there is another one for M8 from geekbuying.seems like its having same problem ethernet and wifi disconnecting..i dint know if they are the same as this one here or not ,hvent got the M8 anymore to test,,??it looks likenits the same firmware as geekbuying..[emoji1] [emoji106]
There are currently 2176 users online. 1 members and 2175 guests.
