I own the device from new (both in December) and had no problem but last time I was watching some video stream and I got the message that the internal memory is running out.
I checked - yes - internal memory is 2GB only... and 700mb free... the rest is shown as usb0.
I wanted to extend it as I have found that it is possible when device is root'ed.
I have read this forum and the problem I see is that all info is for rom's 1.8
Mine was recently updated (updates comes by automatic notification). I think previously it was 2.0_20141111 or something similar.
I have no idea is it a genuine supported rom or not but this is how it comes in the box so I believe so.
Can someone please tell me what file to use to root this device and what to use later to change the partition size ? Do you need any details of me ? This is Cube 9x white 16GB version.
I don't really need to root it if I can resize if without it.
Marcin.
