Most china devices are ship with a blank regulatory domain for wifi. All good wifi chip like broadcom(rk901,903), ralink mediatek, realtek... should work properly as it was wifi dongle for pc but with proper software.... not blank crucial part of code, none of wifi chip is so cleaver to learn himself how to work.
You need to set ro.wifi.channels= in build.prop for things to work properly
US Wi-Fi standards and broadcast channels are limited to 1-11
UK have different regulatory standard for WiFi allow broadcast on channels 1-13
in all rom from china that i know ro.wifi.channels= is always blank here's a major problem to get stable wifi
ro.wifi.channels=11
wifi.supplicant_scan_interval=90 must be set according to your device, 75 or 90 for rk901,rk903 chip is good. possibility are 15,30,45,60,75,90,105,120,135,150,165,180.... for my pipo 90 is fine but drain battery faster...
i also edit /system/etc/wifi/wpa_supplicant.conf
ctrl_interface=wlan0
to
ctrl_interface=eth0
so far my pipo m9pro 3g has not dropped wifi yet. also in android ui wifi ap scan my 3 router won't stay forever in 'not available' status when i'm 6 feet away... four blue bar wifi signal show real strengh of signal now from 1to4 in real-time (also in android ui wifi ap scan) , status bar show wifi won't stuck to full bar anymore when the connection is drop....
MOST IMPORTANT: now i got stable wifi and could be 200ft away from my router, can connect to mall wifi without going on the roof
bring a fix for gps to my m9pro 3g will be the next level....
