Tablet dead (possibly after using wrong charger!)
    Can anyone help? I have a Pipo M6 (actually it's a Sumvision Voyager 297 which seems to be the same for all intents and purposes).
    It suddenly will no longer turn on at all, and shows absolutely no sign of life.
    I went to check the charger, and realised I've been using the charger for my Chromebook, which seems to charge at 12v, rather than the Sumvision's 9v. I suspect this might the the cause of the problem, but I must have been using the charger for some weeks without any problems until the tablet died.
    Thanks for any suggestions on how to fix it or where to send it to be fixed...
    If it is properly beyond salvation, what's the best replacement? Is there a newer version that I should consider?
    Anyone? If not, does anyone have a use for a dead tablet?
