Mk809 plus
recovery button
Originally posted by gjs999 View PostAny one flashed one of these units , if so can you post some hints , where is the recovery button hidden and any drivers fir win7 (get mtp error at present ) .
Originally posted by mattrb View PostCrack open the case with an object and look for recovery button, if fail, use adb to get it to recovery.
good luck
Originally posted by minonano View PostI already opened the unit its very easy, nothing like a reset button there, installed finless as per his instructions, Zip file+revovery file on SD card then used the app called update, select then upodate.
good luck
thanks
can confirm no recovery button on this unit
Originally posted by gjs999 View PostThanks for that -- so you used the mk808b plus finless rom -- did you notice a difference from the stock rom and did wi fi fully function.
thanks
There are currently 3974 users online. 0 members and 3974 guests.
