echo "n" > /dev/video_state echo "p" > /dev/video_state
I use that method all the time. I set performance mode (800MHz) when needed (mostly games, sometimes file compression) and change to normal (650MHz) otherwise. My overclockmatick_RK3288 rewrites those frequencies with two highest values for DDR memory in his config file as performance and normal respectively.
In RAR application benchmark I get ~2MiB/s in performance and ~1.8MiB/s when in normal mode. That's only 10%. Nothing to die for.
Also this path is much nicer: /sys/devices/system/cpu/
