Q7 XT-Q7V-V10 20140815 ROM LIST AND SMOOTH XBMC/KODI
    HI people!
    As you know threre are many different boards/pcb for the same device RK3188 CS918 Q7. For that reason I want to create a list with the ROMs for our specific board and then we can see which one is the best.
    Q7 XT-Q7V-V10 2014-08-15
    I tried different ROM with the next result:
    1. update_7_30: WORKING
    2. Q7_30_11_2014_KITKAT_ROOT_GAPPS_MAC_droid.img: WORKING AND ROOT
    3. Q7V 中性 13.2xbmc 12.9 update: WORKING WITH XBMC
    4. update_EKB311_20141209.zip: WORKING WITH XBMC
    5. update_Q7_20141209 (382MB): WORKING WITH XBMC
    6. update_Q7_20141226 (383MB): WORKING WITH XBMC
    7. EKB311B(CS918)_no logo_ROOT_4.4.2_20150122.zip: WORKING, ROOT, WITH XBMC BUT BAD ZOOM SCALE
    8. update_7_4: WORKING WITH XBMC
    Also I tried different ROM for Q7, CS918, RK3188 but they DON´T WORK:
    EKB311B%28CS918%29 Android 4.4 固件-07.10
    cyxtech_cs918_8723_box_140731_8G2G.rar
    cyxtech_rk31_cs918_8723au_4.4_140802_8G2G.rar
    A31s_sun6i_android_mars-ov5640_20140219_
    K-R42_HFW_3.2F_by_lewy20041
    EKB311 firmware %2B RKupprade tool.rar
    EKB311B 2013.12.31.rar
    Q7_1220_update.rar
    ap6210_kitkat_finless20_beta2.zip
    Q7_firmware_by_Vector_RC3.zip
    Q7-firmware-update-xbmc.ZIP
    Q7-firmware-update-xbmc_by_veclinux.zip
    GuruX7_Malipatch_HLS_v5.zip
    EKB311B%28CS918%29 Android 4.4 固件-07.10.zip
    rk3188_4.2.2_box_q7_v001_20140227.zip
    radxa_rock_pro_android_kitkat_hdmi_140924_nand.zip
    MK902II_141227.rar
    update_cs918_203j2104_overseas.rar
    update_cs918_203j2104_overseas.zip
    update.img
    Q7_Firmware_By_lewy20041
    update_mk918_206j2105_overseas.img
    A31s_sun6i_android_mars-ov5640_20131202_.rar
    MK918 1.24.rar
    EKB311B_MM_KK_ROM.7z
    update_Q7_20141209.ZIP
    cx919_422_finless_16b.zip
    nepumuk_mk918_kitkat_4_4_2-v0_2.zip
    Cs918 v7.0
    cyxtech_rk31_cs918_8723_140814_8G2G_14年hdmi_ic.rar
    Q7 RK3188 168967 20141212
    Cyxtech CS918 KitKat 4.4 Rooted
    update_140805_时代智控_8188_单wifi
    Do you know other ROMs?
    Which ROM is the best for our XT-Q7V-V10?
    Also, Which is the best smooth XBMC for each ROM?
    What's about the idea to give the links to the working roms?
    RK3288 Devices
    - Overview BOX (LINK !)
      Very easy! just write the ROM´s file name without extension on google
        excellent work
        I am currently with update_Q7_20141209
        it works OK (sometimes I have to reboot to see a wired mouse)
        it has XBMC 13 Gotham, I manually updated it to 14 but it has problems. So If you have this ROM you 'd better stick with XBMC 13
        If possible it would be very helpfull to make a table mentioning "rom release date", loader ver, root , problems, etc
          Thanks for your work, i have a question about EKB311B(CS918)_no logo_ROOT_4.4.2_20150122
          Can you describe issue with bad zoom scale?
            in mine box with this firmware some options are missing in display tab, also you cannot make the analog output bigger or smaller,
            also some other options were missing from settings but i can't remember details, I only kept it for 10 minutes
              I'm searching rom image from Hannspree Android Box SNNPB73B. This is fresh product from Hannspree and maybe its the same platform as XT-Q7V-V10...
              I have touch monitor from Hanspree HT231HPB, http://www.hannspree.eu/de/monitors/ht-series/ht231hpb, but neither stock rom support that.
              Maybe rom from Hannspree device has other features.
              ohh, one more... i found EKB311B(CS918)_no logo_ROOT_4.4.2_20150122.zip
              Dowloaded from first link, https://mega.co.nz/#!NgBEmRyb!8KXHbM...eJFKz0A0wi3OQs
              Root work, but I don't take rw access for system folder.
              Doesn't work any mount /system app fromstore.
                Okej, dear community. After many attempts I made a kernel which works with cs918 xt-q7v-v10.
                USB, resolution fullHD, sound, LAN network,touch screen with Hannspree HT231 work now.
                Don't work Wifi, BT.
                Below link to my kernel and stock kernel from last stable rom (14/12/26)
                I based on radxa source for Android KK and Ubuntu 14.04 LTS.
                Case how to build own kernel for cs918 with working touch screen in HT231 device is closed for me...
                ...but I can help if anyone would want to continue my hard work .
                For example I have dmesg dump from stock and my compilation,
                Now I have Wasser firmware k-r42 New 1.0.4 with my onw kernel.
                Link to my kernel:
                Link to stock kernel:
                You can try how it works with custom firmware and stock or my kernel.
                  @Switch4DT
                  Because of WiFi and BT maybe this helps a little bit
                  Demontager's Quick Guide http://nixtalk.net/kernel-rk3188
                  (source: http://freaktab.com/forum/tv-player-...839#post239839)
                  RK3288 Devices
                    Link to my kernel:
                    Going to try this with my personal boxes. Shame we can't get wifi working with Wasser firmware. I've been away since December so I'm way behind on everything.
                    Looks like I didn't miss too much though. From what I can tell this is the best development yet for our perticular Q7 boxes.
                    I'm not even sure mine are 10v. I think they are 11v. I remember something about them being compatible anyway.
                    Either way thank you for the work.
                      i have same mainboard(XT-Q7V-V10) 2014-08-15. it is ekb311b
                      chips:
                      SKhynix H27UCG8T2ETR
                      SKhynix H5TC2G43EFR x4
                      REALTEK RTL8188ETV
                      MEDIATEK MT6622N or MEDIATEK MT5622N (i cant see)
                      Rockchip RK1000-S
                      ite IT66121FN
                      ACTIVE 88460M CE035
                      DRV632 4BTG4 CK5Y
                      FE1.1 USB 2.0 HUB
                      i am searching for roms...
                      @chinchi
                      what is your chips?
                        Link to my kernel:
                        @Switch4DT
                        We have same boards but different sdram chips. your is ISDT mine is H5TC2G43EFR...
                        Can i use "Wasser firmware k-r42 New 1.0.4 with your kernel" this rom?
                          Hi! Anyone tested a webcam with those ROMs? I am currently running update_Q7_20141209, everything seems to work, but the webcam has very dark image (it is a Logitec C270 which works fine in a PC).
                          Also, I saw some posts abount installing Linux in the box... does anyone recommend this?
                          I would appreciate any input on this...
                          Thanks!
                            Chinchi....have you tried or do you know any ROM for our XT-Q7V-V10 with TUN.KO module compiled ? I would like to use a VPN app but its impossible because of that. I've tried downloading TUN.KO INSTALL app from Google PlayStore but no works!
                              Hi everyone, what method are you using for flashing this roms?
                              No luck for me. i have the same pcb.
