Nextbook 8 (NX785QC8G) shutting down on its own
Hi, I have a Nextbook 8 (NX785QC8G) for 2 months now and every time i try to use it, It shuts off on its own. I've fully charged it, tried it at 83% and 50% charge and i have even try factory resetting it several times nothing changed. What can i do ? it is annoying
Tags: None
Originally posted by Mike3 View PostHi, I have a Nextbook 8 (NX785QC8G) for 2 months now and every time i try to use it, It shuts off on its own. I've fully charged it, tried it at 83% and 50% charge and i have even try factory resetting it several times nothing changed. What can i do ? it is annoying
You'll most likely have to remove the back of the tablet, unplug and firmly replug the batter cable and consider options to prevent the cable from pulling loose again.
ShaunMTFreaktab Rom Developer
Google how to remove the back cover for this model and you will find instructions with pictures.
Take you time, be careful, don't use too much force and you will be fine.
In my case the plug was tight. I removed it and put it back in place and the tablet works like a charm again.
When I replaced the back cover I didn't snap it totally back in place in case I would have to do it again in the future.
There are currently 2986 users online. 0 members and 2986 guests.
