ROM STOCK ac8350 (BX09) ?
Hi there! I have an TV SMART BOX, with Android 4.2.2, an processor Cortex A9 Quad Core, 2 gb ram, and 8 GB ROM,It is a AC8350 (BX09) model with a RK31SDK, is attempting to install a ROM which came not successful, and now try to find the Stock ROM can someone help?Tags: None
AC8350 BX09
Should be
CH001 xxxx TN-BX09_V2.1
pcb, where xxxx means new or (like mine) old rev and should work with JB and KK rom by wasser ...
To be sure which pcb, you have to open the device (4 screws under the rubber feet)...
But I have no idea if you will find a stock rom...RK3288 Devices
- Overview BOX (LINK !)
Update
Hello! After installing many ROMs, various "SMART TV BOX", I got one that worked for me, but there was a problem, not the Ethernet adapter or wireless adapter so detected, the rom was one of the R-BOX brand. Then I tried several ROMs and none do anything appearing on the screen at power up. Is there anything I can do? Maybe add drivers to the ROM?
No, these are parts compiled at/into the kernel... (that's why there exists old and new rev at wasser roms)RK3288 Devices
There are currently 2384 users online. 0 members and 2384 guests.
