Cube Talk 9x - SD card problems
    I got a Cube TALK 9x, along with a Kingston micro SDHC 32gb class 4 with the words taiwan on it.
    I've been trying to work out why I can't install my apps on the SD cards and realized its probably from an incompatibility... but according to what I've read, kingston 32gb micro sd card are ok.
    Currently I can move apps from internal storage to usb storage. No other option.
    Didnt do anything but update to v2.0_20150114
    Can someone provide help on this?
    (newbie to tables, but not pc stuff)
    Originally posted by Zavia View Post
    I don't understand your message. Talk 9X has only 2Gb app space (internal storage) by stock. You can't install apps to usb-storage or sd-card without root or mods. When you say that you have moved apps from internal storage to usb storage do you mean that you have moved only app's data? That can be possible. However KitKat doesn't allow to use sd-card for that. You need root for writing to sd-card.
    If you only need more app space I suggest you to use EBR files method. You can expand your app space from 2Gb to 4Gb or 6Gb with Brian's mod. Also you can expand app space to 10Gb or 13Gb if you have 32Gb Talk 9X tablet for sure with azaotl's or linuxovios's mods. You can find mods and instructions from Talk 9X info thead.
    EDIT: Here is guide and all information how to increase app space up to 10Gb (16Gb models) or 20Gb (32Gb models). Thanks goes to gdp77!
    Could you also check this post, please. It is about FOTA updates that you have managed to perform. I am struggling with FOTA.
      ..... after rereading, that suddenly makes so much sense.
      I assumed that I can install the stuff to the SD card. Heh.
      Good thing I got a 32gb. (hearthstone alone takes 0.94gb)
      Thanks!
