Help Identify this box
    I bought this box from guy out of the trunk of his car.
    I tried installing Kodi after deleting XBMC which worked fine but the audio is out of synch when watching prety much anything. Figured it might need a firmware upgrade, can you point me to the right firmware for it? Screenshot attached.
    Model: M8N
    Android Version: 4.4.2
    Build Number: KOT49H.20140904 test-keys
    Kernel Version: 3.10.33
    huixian.li@wyst #1
    Thank you.
    Hello,
    Here you can Download the New Rom --> http://pan.baidu.com/s/12Lw2U.
    Neomode
      Thanks for the information. Will the other ROM's posted is this sub forum work as well?
        I have M8N, here's another good rom:
          http://mbox.co.za/forum/viewtopic.php?f=64&t=336
          Loaded up this rom and it's working great. Appreciate all the help and the information!
