Hi ,
I have microsoft wireless keyboard (http://www.microsoft.com/hardware/en...media-keyboard) I've connected it to the HPH and noticed when trying to enter WiFi password , the buttons I hit are typed multiple times (like sticky buttons) , When I connect the same keyboard to my Minix 8H in the same distance exactly , it works fine.
Try to use the OTG port...
It seems to be a known problem with some keyboards at the rk3288 devices...
The OTG is connected directly to the rk3288 while the other ports are using an internal hub-chip...
Will try , but still this is a problem that needs to be fixed
You can get various results even with the same keyboard, on the same usb port. If you have multiple input devices like me, such as keyboard, gamepad and air mouse, it even matters the order which you're plugging them in! When it happens to me, I unplug all wifi dongles, and first connnect my keyboard, and then it's ok. As a general note, keep you wifi devices apart from each other. Most of them emit signals at 2.4Ghz, so interference is the most common issue. Even your wifi internet works at 2.4Ghz, so you can get lower speeds and connection issues if your wifi dongle is connected directly into usb port on the box. Also try using an usb hub with longer cable, so you can put it away from the box, or buy an usb extension cable and connect your wifi dongle to it. There are many more solutions like wifi signal shielding, but it requires a bit more work and patience to set up everything. Just google it.
