Arnova 10 G2, 10b G2, 9 G2, 8 G2, and 7 G2.
You have to trust me on this, it will be WORTH THE WAIT!
Boot times are better, Android Market 3.4.4 is pre installed. No trying to work at getting it installed with tools POST install of the ROM. I still can't guarantee successful login of the Market but I am willing to bet it will work MUCH BETTER!
- 1 Gig memory for install apps space! The max capable!
- All versions will support the Arnova patch for their 3G stick
- Flash 11.1 support is a MYTH.... So you will need to install flash 10.3 as I have removed it
- FULL ROOT! As with all my ROMs, I was the first to crack and convert the Arnova's /system from a read only file system (cramfs) to a EXT3 read and write file system! So this is a TRUE full root! Some ROM's out there that used my techniques to convert, still do not have some things right! (I have learned a few things since the original convert!) /system is a well managed and formatted ext3 file system! Additionally, some ROMs I have been seeing coming out recently also do not have proper ownership OR permissions for /system. 100% Mine do
- SU and Superuser.apk is installed and up to date with 6777 permissions. Some ROMs out there still do not have this right!
- As I said. Google Market AND Appslib PRE-installed... No screwing around with installer apps with lots of headaches!
- All G-Apps are up to date! Unlike other installers etc, my G-Apps are up to date as of 1/27/2012. So you will not go to the Market and find you need to update anything!
- NO APPS and bloatware installed! I will post a link to the pre-snstalled apps so you can pick and choose what you want from stock built in apps.
Anyway my ROMs will be up very soon! And I mean in a few days worst case!
I am working hard to give you guys the best TAB experience I know how to do. So hang in there. I have some more testing to do with others and soon you will have JOY
These WILL BE FreakTab exclusive ROMs. AND no dealing with BS upload sites with timers, limits, pop-ups, SPAM and possible viruses or other exploits that can jack up your PC! FreakTab downloads will ALWAYS be here with no BS.... THAT is why my partner and I made this place! We got tired of trying ROMs that don't work right and dealing with the BS upload sites pop-ups, timers, SPAM, and BS.... Time to get your TAB ON with no screwing around!
