I am following the instruction on the site but my computer cannot recognize the device although the drivers seemed to be installed orrectly.
Bricked my MK808, can you please help-I am so sad :(
Originally posted by borisb View PostWhat do you mean to uninstall? The drivers?
Also the flash tool does not change. I hear the USB connect sound though.
Is the pins supposed to stay connected?
Are you sure that the correct driver is still installed?
Originally posted by mellodroid View PostSorry. I'm typing in my phone and somehow spliced in part of another post at the beginning. If you have tried resetting and it doesn't recognize the device you should follow the procedure in the link. Don't uninstall the drivers if you have the correct ones.
Everything worked, it was soft bricked after all.
Bobs rom is JUST AWSOME!
There are currently 1274 users online. 0 members and 1274 guests.
