TVLauncher PRO - v2.0 - BETA 2
    TVLauncher v.2.0 (beta 2)
    - coming tomorrow (hopefully, at least this weekend)
    I have a lot of exams coming up and need to place my focus on school as well
    Features added/changed list (It's getting long )
    - Add single tiles
    - Tiles can have:
    __x Image
    __x App icon
    __x App name
    - Tiles are now rounded
    - New icon set
    - Weather can be removed
    - New dialog for adding tiles
    - At least two tile screens (This due to current performance. Will look into option to add more)
    - App drawer fixes (This element is using a lot of "juice" so I placed it in an own activity. Will take some time loading - will look into it later!)
    - 12 x 2 Tiles (TV/Tablets)
    - 6 x 2 Tiles (Galaxy nexus) (I'll make a layout for Nexus 7 & Nexus 10 later)
    - Restart added from menu
    - HideBar is now an experimental feature
    - Choose Light or Dark ActionBar icons
    - + Things I've forgot
    These are signed up for the upcoming beta:
    - bay1902
    - craftaz
    - teisner
    - baluvee
    - jlcd
    - Fobz
    - endera
    - Mow
    - Gasp
    - scigo
    - carlcorr
    - murat0606
    - shapeshifter
    - modrica
    - netghoster
    - rfve
    - hennieh
    Please comment!
    WOW. Cant thank you enough m8.
    As earlier said, Im using this on a MK802, soon getting my MK808 and must say this Launcher is a must!
    You really made my day with this launcher
    Bought it and gave you 5 stars at the store.
    Hilsen fra kristiansand
      OthrEr IDea Could Be EnavVle ConnectibVity Whit A Celphone Or Tablet To Be Used As Mousepad. Pr.CcoUlbD Be ExvCellent Enable The GyroscppOpe Of The Celpho To Use It As A Flymouse.
      Otherr Idea Is To Use A Celphone As A Remote Control Whit Basic Buttons Like Vol Up Dow BackK Home Etc
        There are a lot of apps in the play store that offers what you want. Just download one of them
          I use "Droidmote server" on the stick, and "droidmote client" on my phone to controll it.
            i know that. but i could be excelent idea to have this implemente by default in te interface.
            use the celphone as a flymouse is NOT implemented in droid mote and will not be implemented.
            the idea is to make something more simpler.
            like a touch pad mouse
            other a flymouse option with the basic bottons of android. and not too much more.
            and the up down arrows click, back and thoes ones nothing more. may be add FF FW stop play too.
            btw the only app that that realy works is the droidmote. there are not much others. i allready have the application (droidmote). and in my case does not work very fluent dont know why.,
              Most likely due to wifi issues. It gets especially laggy when you try to use it with streaming video. Even on devices with very reliable wifi it is not ideal to try and control them with another wifi device through a router especially when utilizing bandwidth for streaming. A direct connection from phone to device would be better but I'm not sure if this is supported in any of the ROMs available for these devices yet.
                Idea/Request
                One thing I'd like to see is the ability to put custom sized widgets on the home screen (like in Zeam Launcher).
                  make the icons like iPhone
                  Add glossy effect
                  Round corners
                  Add drop shadow effect
                    Re: NEW - TVLauncher PRO - v1.5 - Two Favorite screens
                    Wow! What keyboard are you using? Can you get a refund?
                      AW: NEW - TVLauncher PRO - v1.5 - Two Favorite screens
                      Really great launcher... bought it 1 hour ago in the play store...
                      My recommendations:
                      - possibility to always enable search bar ... it's really fast - great!!
                      - next step: searchbar searches apps, in apps and the web (like quick search app)
                      - folder support.. very important for me... i've many games and apps... always searching these is not fine.. i'd like to classify them.
                      Would be very very cool to put apps/games in a tile. Tile name is for example "games" with background image.... if klicking on this tile
                      the folder opens with the app icons.
                      - next step could be arranging icons in the folder
                      - would be nice to have a recycle bin to directly uninstall apps in the appdrawer
                      - tiles could be smaller for my taste, therefor more tiles or 6 tiles and at the bottom 3 smaller tiles in a row...
                      - possibility to not only chose android settings as a tile, also to have the possibility to choose a submenu in settings (bt, wlan, applications, display, ...)
                      Only some recommendations... would have much more :-)
                      Regards heli
                      Gesendet von meinem ASUS Transformer Pad TF300T mit Tapatalk
                      OK - created some tiles... or folder tiles if this comes hoepfully... could make more...
                      new one:
                        Sorry I was tryping fast in a very small screen. And I got anoyed lolol
                        Sent from my GT-I9100 using Tapatalk 2
                          Please share all ypur ideas. As every one is doing so, the laumcher can be enhanced.
                          The development is neing very fast and all the good ideas that people is shaing are being implemented.
                            Originally posted by rodnheli View Post
                            My recommendations:
                            Regards heli
                            Like your tiles...
                            Very nice.
                            They can be added in gallery and selected from there.. Right?.
                              Thanks guys! I'm grateful for all of your comments and ideas. You're a great support for this project.
                              One thing that is important for you all to know is that things take time and I can't fulfill all you wishes at once or within a short period of time. But know that I am constantly working on things you all are proposing.
                              I want you all to know my focus area of development at the moment, is with tiles. I've seen a lot of people here that would like smaller and more tiles on each slide. And that's what I'm doing. The process of making them smaller, and more tiles etc. is easy. But as of now, the app is a bit static in some regards. And for TVLauncher to be as good as both I and you want, I've redesigned the whole dynamics of the app. I'm in the works of implementing a database, new interface, adding and removing single tile elements etc.
                              I've come a long way but have a lot of work a head of me.
                              Here are some screens of my current work:
                              Please continue to support and tell all of your friends.
                              Sam
