I have a UG802 running finless 1.6 rom
My ug802 suffers from a strange behavior, the HDMI output blackouts for a sec or two every once in a while
In some applications or scenarios the blackouts a more frequent ,when running XBMC it blackouts every couple of sec , when using the unit in other apps the blackouts are less frequent (every couple of minutes)
This behavior is only happening when the HDMI output is set to 720p. when setting the output to SD resolution i don't see any blackouts (but its not a solution
The ug802 was connected with the original HDMI extender that came with the device and directly to the TV (Samsung 650A if it helps) and it still behaves the same way
I tried changing the power supply to 5.1V/2A Ipad power supply but it still behaves the same way
dose someone see this blackouts on his device?
can someone please help with an idea what can cause this kind of behavior and how to solve it?
facts:
- in some apps the blackouts are more frequent ,xbmc for example
- the unit is connected directly to the hdmi input
- it happens even when using a strong power supply
- the blackouts are only when setting the resolution to 720P, not on SD
Thank you
Dan
