Polaroid 703C Help
    Polaroid 703C Help
    Looking to add the Google Play marketplace. I tried following tutorials for the other tablets and am met with constant force closes from the google play and marketplace apps. I was able to get netflix from another marketplace and it does absolutely nothing when the app is launched. Sorry for the crappy typing, I'm trying to get this tablet set up for my wife and I've been stressing over this goofy thing all morning.
    Hi there! I just went through this on my new Polaroid PMID10C this morning. None of the Google Play install methods that used to work on Polaroids worked. I ended up trying a more recent batch of files someone has used to install Google Play on a Kindle Fire HD. It worked just fine! Not sure it will work for you but it did the trick for me. Details on the easy install can be found HERE.
    As for the Netflix App...the most recent one has refused to work on either of my Polaroid tablets. This morning I downloaded a slightly older previous version of Netflix and it seems to work just fine. (I think it's version 1.8.1). Definitely worth a try! You can get the version of Netflix I'm using HERE.
    Just keep in mind these are files provided by someone other than me. They worked fine for me but like anything else when tinkering with these things.... use them at your own risk!
      Did you have to root the tablet? Is there a guide for this? Tried these files, google play still force closes on me
