MK808 Netflix problem
    Hi, just received my MK808 from Geekbuying, nice quick service to UK, put the Finless 1.5a ROM onto it, also put external WiFi aerial to improve signal, first off it would not connect to the market or netflix via my router, web was fine and Google logged in etc, so connected via my mifi dongle over 3g and market and netflix worked fine. Then went back to the router and the market is working fine, but i just cannot get a connection to netflix. I've reloaded netflix, cleared cache etc etc and still wont connect, even tried different DNS settings on router and turned off WIFI firewall protection..... but it still wont connect to netflix.... anyone got any good ideas what i can try. I also notice sometimes, that the market appears I can scroll through Apps and for some reason it wont download some of them, says connection timed out, but if I push them to the unit from my pc the apps download and install no problem. I've even tried different ROMs and get the same problem, any help appreciated.
    Re: MK808 Netflix problem
    I am having same issue. No matter what I do I cannot get Netflix to work with either my mk808 or my Aoson M11.
    Sent from my M11 using Tapatalk 2
      I am having this same problem. Every other app works just fine and internet connection is fine, but the netflix app isn't working. "Netflix is trying to connect to the available network" is the error message what I get. I think the issue is with the router, which is Netgear N300.
        Hello.
        Does anyone know how to get bigger sub font in Nettflix
        They are just so small....
        Tanx
          The last version of Netflix that is confirmed to work on the Android Mini PCs is Netflix 1.8.1.
          You can download from https://www.dropbox.com/s/vjcg471do3xjmak/netflix-1.8.1.apk
          I have used this version on all my reviews and so far it has worked on every device I have tested it on.
          Quad-Core Android Mini PC Buying Guide | Must Have Apps for Android Mini PC
          Androydz.com - Everything Android plus a little more
          TopChinaTablets.com - China Tablet Ultimate Guide
          GetdatGadget.com - Gadgets That You Want
            I am currenly running latest version of Nettflix on MK808
            Only issue is that subtitles are to small.
            On MK802, Nettflix 1.8.1 is the only working I think.
              I tried the version 1.8.1. but Netflix isn't working. I can install it normally, but when I start the app it only shows the loading screen (with Netflix logo on it) and nothing happens. After 1-2 minutes of waiting it only says "Netflix is trying to connect to the available network". The app doesn't ask any netflix login username or password, it just shows the loading screen.
              I have tried the Netflix with Finless 1.5a custom rom and the original rom: the result is same.
