Mk808 has good signal, no internet connection?
    Newbie here, running finless Bob 1.5a, I can see my router, even my neighbors occasionally. I logged in, just no connection?? Thanks gang
    I had this start happening to me the other day. Turns out one of the solder points (the actual pad) tore off the antenna (there are 2 solder points) So I took it home and removed the pad. There was another unused pad that I soldered to on the antenna and that fixed the issue. Before I had great signal but the wifi indicator would stay "grey" after fixing it it would fully connect to the internet and turn "blue"
    TV Stick: MK808 // Tronsmart T428
    ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
    CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
    Recovery: ClockworkMod
    Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
    Phone: Samsung Galaxy Note II
    ROM: Whompasaurus v4.2
    Kernel: Persus
      Thanks brother, took it apart 're soldered the antenna, all good now.
