1. Get Market installed on your PMID4311 following Nate's instructions found here:
2. Go into Google Play Market and search for SuperUser app and install it. Open SuperUser app--> settings and update it. Reboot
3. Go into Google Play Market and search for Terminal app and install it.
4. I am using the 5.5.0.4 Recovery found in this link provided by William Kleiman. https://docs.google.com/folder/d/0B4...WUE/edit?pli=1
Copy Recovery.img and install-recovery.sh to root of internal sdcard. Run terminal app and type the following:
>su
#>cd \mnt\sdcard
#>sh install-recovery.sh
5. Hold Power and shut down tablet.
6. Hold Volume + key while hold power button. Once Polaroid displays on screen, release power button while continuing to hold volume + key. Once you are in Recovery, you can navigate the menus by using volume + and volume -. The power button is the select or enter key.
Note- It does mess up the mounting of your SDcards initially on first reboot of ICS. Remove external SD card after 1st reboot after recovery install for stability.
Yes, I own a PMID4311 that came with ICS 4.0.4. Yes I tried this on my own tablet and it reboots and mounts both SDcards fine everytime.
Update 12/9/2012
Dolores Park has developed a kernel fix for CWM 6.0.1.2 for ICS with 10 Partitions (OEM 10 partition layout) provided by Dolores here:
**Do NOT install the 9 partitioned edition, install Dolores Park's CM10 IMG file with LiveSuite to get 9 partitions first.
